[FOR SALE] sb mopar parts
340 man
lake arthur
I have a hughes hyd cam-lifter with about 50 miles on it in a 340. duration @ .050 is intake 223 exhaust 236, int lift is 512 exh is 518 it the whiplash cam $125 pluse the ride I am in Jennings la. 70546. also have new sb msd dist. with msd 6a box $250 plus ride. also have 1 bare x head $100 plus ride,also have a set ove 273 adj. rockers $125plus ride.also new sb csr elec. water pump $150 plus ride.sb 90degree oil adapter,$50 plus ride.must sell need some cash.
keith jon from wisc here what is the lobe separation on the cam ?/ LSA I could try it for $110.00 shipped to help yah out my comp cam 20-227-4 is $135.00 new and shipped but what I could use is a water pump that has holes for my alternator bracket bolts, and my power steering bracket , it has different tabs for the holes than the new ones ,my engine is a 69 340 and the 1 on my 71 360 looks different It has no tabs with holes for brackets sticking out on both outsides see if you have one of those laying around with no slop in it and bearings are good yet , I want to run the old shool brackets , so I need the older waterpumps that the hose comes out the drivers side of the motor see what you got and if I try the cam it cannot have any wear to it must be like new is that duration or advertised duration and what lsa? give me a holler jon 1 608 837 4427
