SB non AC pulleys
Saetun
Sinister Swinger
Pittsburg, CA
While doing some work under the hood, I finally made up my mind to delete the AC on my 318. I pulled all the AC equipment & got the brackets needed but don't have the pulleys for the water pump & crank. I believe they are a double groove pulley for the crank & single for the water pump. Anyone got a set that I can put to use? Thanks.
Jeff
