3406pk
I'm rebuilding my 340 from 72 Challenger after the machine work. Bought a used set of 273 rockers which look good, but most of the 5/16 bolts Gr5 were stretched. I know about the torque specs being wrong at 30 lb-ft. Put in adjustable pushrod checker and ordered the new custom pushrods. I put in new Gr5 bolts and torqued to 15 lb-ft for the test, but that tension seems loose for higher pressure springs. Question Is there reason not to use Gr8 bolts at proper torque of 18 lb-ft? Has someone used Gr8?. Thanks for response.
