[WANTED] SBM DOWEL PINS HEADS TO BLOCK
V24x2
MOTORCITY
WANTED: Smallblock cylinder head to block dowel pins shipped to zip 48036 Michigan! Seems everything available is 1/4inch where clearly these are larger, maybe 3/8 or even 7/16. Any help would be appreciated!
Are you looking for new only, or would used be ok? I have a junk 360 block I cut a rear mounting ear out of for someone so it’s going to be scrapped anyways.
The dowel pins should measure .3010 +/-. I just measured the pins on one of my blocks and the receiving hole on a cylinder head.
