SBM header options for a body without torsion bars
70Lawn_Dart
#moparlawndart
Cassadaga NY
Been doing a bit of research but haven't really found an answer as to running a different body styles small block headers on an a-body with coil overs. Trying to find a set thats 1 3/4in primaries for my 360 that wont hang too low. According to tti's website, you can run part# 340BE when you have converted to coil overs which are for B, E, F and M bodies so my idea was that other manufactures could fit also? I'm torn between just buying tti's, experimenting with a different brand or just having a set made. Anyone have any experience or ideas?
Contact TTI and other manufacturers tech lines and talk to someone about your application. Not everything will be on their websites and they may be able to point you in the right direction for your car.
try dirt track headers they are designed for a open engine compartment and don't hang to low
I have a pair headers off of a 68 Barracuda race car with the coilover front suspension. They are I believe 1 7/8" tubes with straight collectors. The flanges are drilled for W2 heads but I have the adapter plates for LA SBM. I don't know what shipping to you would be, that might get expensive. PM me if your are interested & I'll send you pictures & measurements.
Hooker Supercomps for a E body may work unless you run into clearance problem with steeringbox/centerlink or fenders.
