I don’t think the bolt pattern matters related to the backing plate or anything else. I just put an eight and three-quarter in my 65 dart. I used a set of 10 inch backing plates that were on my B body. Everything fit fine. I went with 10“ x 2“ brake shoes and drums. Used all of the internal guts from the 10 inch brakes on my 7 1/4 rear endAs the title says, small bolt pattern 5 on 4" rear backing plates, drums and guts for an 8 3/4 rear axle.
Sorry, the drum bolt pattern will matter. I found 10“ x 2“ drums brand new through O’Reilly’sAs the title says, small bolt pattern 5 on 4" rear backing plates, drums and guts for an 8 3/4 rear axle.
I also swapped to a dual master cylinder. I believe I bought one that fits a 72 or three duster. There’s a specific proportioning valve they sell for this conversion. When I get home I’ll try to find the number. As far as the backing plates go I don’t remember anyone staying they wouldn’t work. I put them on swapped everything over and I’ve driven the car and they work fine.No, not a resto, but I would need a new master also, and proportioning valve.
What do You recommend as far as the disc swap?
Small and large bolt brakes for 8 3/4” will not interchange when using the small bolt pattern axles. They have a unique offset and only run the 10x1 3/4”!brakes.
Your talking about the backing plates?
Is this what your looking for??? You will need the drums or I can get them as well. Thanks
And the drums as well. Everything is based off of the offset of the axle flange as it sits in relation to the housing. It extends out a certain amount, the drum mounts to the face of the flange, and the brakes are back set from that. So, since they are set to use an 1 3/4” shoe, and the shoes are mounted to the backing plates, a 2” shoe would be too wide, and a 2” drum would rub the backing plate. Redrilling the drums and axles is the old school way to use the existing brake setup for a large bolt pattern. Nowadays, they make up that difference in an aftermarket axle already drilled for large bolt and offset to use large bolt brakes of any configuration. Of course, Dr. Diff still sells axles in the original 1 3/4” offset that would only require redrilling your drums if he makes them with the large bolt pattern and you still want to use your existing brakes.
confused yet?
Not sure, what size are they?
Factory A-Body 8 3/4 backing plates with hardware.
Well, kinda. I stopped at O'reilly's, they have 10" SBP drums, but she's telling me they use either 2 1/4 or 2 1'2 shoe's, can't remember which, 56 bucks each, one day wait.
