[SOLD] Scat 9000 Cast Steel Crankshaft and Eagle rods
Bob1958
Washington state
I have a standard journal Scat 9000 Cast Steel 273/318/340 3.58" stroke crankshaft
Crankshaft is in very good condition.$300 OBO +shipping from 98632
Also have a set of Eagle I beam Rods with APR BOLTS very good condition $200.OBO +shipping from 98632
What’s up with the pistons? R they 4 sale? What bore r they? Kim
Kim
the issue with the pistons is I only have seven one was damaged in transport a small chunk of the skirt broke off KB no longer makes that piston in 4.070 bore they stop at 4.060 I looked around could not fine one
So it'a 3.58 stroke but with 273/318 mains? Any work done to it or has it been Mic'd?
If you can buy pistons for this stroke crank you can turn your standard bore small blocks into:
273===299 cu. in.
318===348 cu. in
340===372 cu. in
I miked it it's standard the story I got
Gentleman bought the kit put it in his duster made a few runs then swapped it out for a 4" set up.
The pistons showed very little ware I would have used them if I could have found one replacement. Crank and assy was sitting in a friend's garage for several years.
Bob
If the crank and rods are still available I would like to buy them. I will pm you with my contact info.
