Vaanth
I should not have had the word "axle" in that sentence (removed in an edit). The outer axle bearings (wheel bearings) are not involved and do not change. Keep the axle bearings the same (if good), and just keep the carrier side bearings (inner, cone and outer, cup) with the '741' Sure Grip unit and place in the other housing with your new gears for that housing.so if i were to install the sure grip unit itself from my 741 unit into, say a 489 open diff center to make it positive traction, i would have to buy the outer axle bearings (wheel bearings) to install on my axles that would have been on the axles used in the 489 case? am i understanding this correctly? Im guessing there is not enough adjustment on the passenger side axle bearing adjustment? Or could i just use the green axle bearings for any of the 3 different carriers?
