[WANTED] Schumacher Dakota small block engine swap mounts.
BigStrok3
Mopar!
St.louis area
Looking for a set of schumacher dakota 340/360 swap mounts for a 1st gen dakota. They don't make them anymore and have no plans to. I can fab my own but would rather find some if I can. I'm located in Wood River , IL don't mind paying for shipping. Thanks.
Here's an easy mount my son made putting a 360 in a tribute truck .
Hope it helps .
Cheers
Ok so that means you do need mounts because LA blocks don’t have Magnum motor mount bosses. If you put a Magnum motor in it the V6 mounts should work.
Ahh yes the fabled dakota magnum to LA swap mounts. I hear hens teeth are more plentiful.
Not selling, but I was recently quoted over $1500 to copy this set.
I will be stuffing my 340 stroker into my dakota shortly.
