BARNEY'S CAR
SGITP
Anybody bought bulk seat foam and redone their own seats? I'm looking for a place to buy bulk correct density foam so I can stop sitting on the floor.
Thanks for your time.
I know I can buy it done (310.00) bought it must be cheaper in bulk. I'm old on fixed budget and building a second car anything to save a few dollars helps.I got correct foam from pg classic it fit right and has supported my 240 lb butt for 6 years .
I bought houndstooth material from this company fast shipping Gene Your Auto Trim StoreI know I can buy it done (310.00) bought it must be cheaper in bulk. I'm old on fixed budget and building a second car anything to save a few dollars helps.
Most of our cars don't get the kind of use they used to and are stored and taken care of better. You will be fine. Using the better methods and materials doesn't hurt on limited use but can be most benifical on a daily or race car where a heavier than average driver
is getting pushed into a seat frame. The photo I posted is a A-100 seat used in a super stock scenario. They were light weight and not particularly up to the task from the get go.
Hope this info helps some of you guys that wish to build a better seat for your A body's.
I don't generally go into this amount of typing on a topic but thought some could put it to use.
It's not always easy to see how and why things are built as they are, particularly when rebuilding your first set of seats.
Stareing at what little you generally have left to work with can be discouraging and cost more coin to have professionally repaired than you have to spare. Luckily much of this can be done at home with
a bit of knowledge, time and materials.
I covered the suspension above so I thought I would add to that a bit.
The foam is nearly as important as the springs and also a portion of the suspension.
Even if it has managed to remain intact over the last
40 years it has lost most of its resilience and ability
to fill a new set of covers.
On the cheap a guy can add a half inch of high density pleating foam to the top of the original and the covers will look good. They won't support or feel as a new seat bun though.
Sometimes this is the desired way to go about the repair such as on a survivor type car where the original covers will be reinstalled. You just want to take the loose squashed look out of it. A new seat bun could put too much pressure on a old cover.
For most other seats the foam is not worth salvaging same as the covers. Hope you have enough for a general pattern if you decide to go the fabricated route.
The ready made foam buns made today are much firmer than what the originals were even when new. This is an improvement for the most part.
A person can build new foam from sheets but may not worth the time for some. It does have some advantages.
If those of you that really wanted to go all out on building the most comfortable seat the foam could be staged. This is done by lamination and is the best construction technique for a quality that is not available shipped to your door in a box.
A first layer of super dense foam would be applied over a layer of fabric & 40oz jute pad. This is done so you wouldn't be able to feel the metal frame regardless how hard you press.
You only have so much space available under the covers so up to a 1" foam that you couldn't crush or bottom out would be a good choice. Then a high density foam layer would go over this. These layers would be glued together with contact cement.
For most mopar seats this is probably soft/firm enough. It really can be taylored to your liking. Take the time to have a sit on your work as you progress to determine how firm is needed for your weight.
If you wanted the seat to be more comfortable for long road trip type driving you could add another layer of softer foam for the top 1"-1 1/2" layer. All of these layers combined needs to
equil the dimensions of the factory buns so the seat doesn't look over or under stuffed when the cover is installed.
You do have to be careful not to use to soft of foam on a reproduction cover since they are stiff vinyl and need more foam pressure to fill them out than cloth or soft leather.
Triple staging a soft leather cover is like heaven over how our 40 year old vinyl seats were built.
My personal favorite seat for our old cars that have had a few modifications is making leather covers in the original patterns and going over staged foam.
It will not be a perfect match to factory stock but will still have the same flavor. Has more of a higher quality look and greatly improved especially in feel.
I wouldn't recommend the leather for a car that is
restored to original but the staging would be hidden.
Cutting the foam sheets into shape is pretty strait forward as mentioned above with your choice of weapon you have on hand.
A regular hand held wood saw works easy for the long strait cuts to get your slightly oversize blocks from sheets. Do this supported on a flat table not overhanging like you would a sheet of plywood.
A serrated bread knife or electric turkey
carver works same as a hacksaw blade for shaving the glued together blocks into the curved shape of the moulded factory bun. I am not going into the details of installing or making covers here but you should end up with a seat worth covering with this info.
