dwhip361
Not sure if this is the right forum for this question but I'm trying to find out if anyone has seen or done a serpentine pulley swap for the LA motor. Any suggestions would be great. Thanks guys.
Any Magnum that can be found in a Durango or Dakota will do.
However! The balanced up front is for a Magnum and not for an LA engine. The balancer/damper is one part with the pulley.
March pulley has them separate. Pulley and damper.
I'm not sure how it may all work out or not. BUT if it is as simple as purchasing the pulley and bolting it on the LA damper for use with the rest of the set up, it would be an easy swap.
