Seven blade fan wanted for 67 273 Commando with 22" radiator
67commando
Spokane
Rating - 0%
0   0   0
I would like to finally replace the four blade fan for a seven blade fan for my 67 Commando with 22" radiator. It overheated again last week on a little trip to Sonic. Was doing fine until I had to circle the block three times - half price milkshake day. I would also consider fan with clutch if anyone has that. I also want to get a shroud for a 68 radiator (22 inch) as the radiator is not original.
If you manage to make this set up work, please let us know the results! I have a similar problem with my non-Commando 273.
I have a clutch fan and a non clutch fan for your car. Contact me if your interested. Bob
Here are some pictures of my cooling system. It worked well and never had an overheating problem, even in 95 plus degree weather. It is a 16 inch 7 blade clutch fan with the shroud and an AC cast iron water pump.
