Sharktooth nice condition
68383GTS
East Peoria,IL
Sharktooth grille very nice shape,better than most.Small crack rh bottom,small crack rh top,top corners cracked where the headlight bezels fasten too.I have the small pieces that are cracked off the grille.The teeth are are there and none are cracked or broken.The grille looks to be mostly original paint except where someone painted the upper and lower section black.The trim that goes the length of the grille on the upper and lower section is beat up some.New parking light sockets.
$750.00 plus shipping
Located in Illinois
Better pics......
The first pic you can see where it is warped.The last two pics are showing a crack.It is a old repair and that part of the grille is warped a little.It would a easy fix if you have ever built model cars.
Jim
Wow can't believe you still have it! If I had the cash I'd give you the 700 and my stock 72 grill. Good luck man.
