[WANTED] Sheet metal
ClassicCarGuy
69 (R6) Red ‘Cuda
Suburbs Phila Pa
Rating - 0%
0   0   0
I want to convert ‘72 demon fenders and quarters to 71. I need 70-71 duster or 71 demon sided marker light sheet metal pieces. Can you help or know anyone that can?
Thank you,
Greatly appreciated!
Thanks, my fenders and quaters r good!
I just need the side marker sheet metal so I can convert from ‘72 to ‘70-71 style side marker lights.
Appreciate your response!
Let me see if I understand correctly.
The 70-71 Duster & 71 Demon rear side markers are the same?
But the ‘71 Demon front side marker is a one year only? What is the difference?
So this means I need to get the front from a ‘71 Demon?
Do you know if there are any other A Body models that would have the same front side markers as the ‘71 Demon?
I’m hopking to get the rears from a ‘70 4 door Valiant. They should be the same. Correct?
Thank you!
71 demon fenders are the same as 70-71 Dart, 71 Demon 1/4's are same on 70-71 Duster 1/4 s You need parts from 2 different model cars to do what you want. I should have both rears need to check and make sure both sides are good
yes...70 or 71 dart for front and 70-71 duster or demon for rear...yes the 70 valiant rear is same
I'd graft sections into your fenders. We've done it several times on different mopars.
Blewbyu
Did you have a chance to check and see if you have the side marker light (sheet metal) for my Demon?
Thx
Your 72 fender s are worth alot
70-71 are easiest to find
That would take care of your problem if you swapped fenders
