Good luck. The arms are the same Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists. They are also the same as 64 to 67 "B" Bodies. The rods are very hard to find. You can usually use, may have to run a die and cut new threads farther down, a later "A" body reverse rod. You can also use Hurst 1-2 and 3-4 aftermarket rods since they used the basically same shifter and mounting plate as the 64-65 OEM Hurst shifters.
Thanks, I actually have the 1-2 rod, looking for the reverse an 3-4 or a whole set. Are the B-body or later A-body the same configuration but just a different length? No problem with shortening and threading if that is an option.
