JGC403
Are all of the Shifter Mechanism the same? The shifter in my car is sloppy, I have a shifter from a truck OD, that feels a lot better. The car has an 833 OD, will the truck one bolt right in?
Yes the od shifter box is the same. You just have to pull the actual shifter arm out and change the rods across.
Jeff
no... the shift pattern is the same. just think 1,2,3,4 vs 1,2,3,OD
