I don't think you'll find much with the usual reverse lockouts and such, BUT there is an aftermarket made by B&M called a "Unimatic"..........it's NOT a complicated lockout or lever protected unit, instead it works similar to the factory shifter, and would mate up easily to the factory console, and it works by cable too (from the rear, also nicely compatible with your console...but again, there is NO lockout....works just like a column shift, but on the floor)....mounts very low to the tunnel too, under the console...............
BUT, you're probably looking for a higher performance unit.........This you'll have to dig for, or maybe someone else can chime in here..............:read2:
