shock length ss springs
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
what shock length is needed. just wondering what everyone is using.
check the size you need, just jack the car up leaving the axle hanging down, measure the distance from the top of the shock hanger to the axle shock mounts. That will get you close. Go to Summitracing, they should be able to get the right one for you.
