No need to do any math to know you were way overloaded and shouldn’t have been on the road.
Yup,no question. People hook up to stuff and "just cause" it PULLS good think it;s ok. Well........lessie you STOP that pup with a decent distance.
That's not actually how it works. The 10k for the trailer is what the trailer is rated for with cargo. It adds zero to the trucks gvw. The 6,800 has nothing to do with trailering. That's the loaded weight of the truck (truck, cargo, and passengers). Your trailering limit is listed separately and will be different depending on how the truck is optioned and the type of hitch and trailer. At 7,700 for the trailer and cargo you were most likely overloaded or at the limit if the truck was max equipped. Late 80's half tons aren't rated for much. 16,800 is modern diesel territory.
It really can be confusing. There's different situations as Rameth pointed out with registrations. That second sticker on your windshield is your weight class, and that you can choose depending on where your vehicle falls on the chart. The higher the class, the higher the fees. Most people don't realize that the model numbers on trucks relate to weight class. A Ford 750 is a class 7 truck for example. There's exceptions of course. Most 150/1500 trucks are class 2, some 250/2500 are class 3, ect.THIS is correct. Thank you for clearing that up.
The important thing to remember is that the manufacturer ratings can't be exceeded. Just because your truck is registered for a certain weight doesn't mean you can legally pull it. It just means that's the slot class you fell in.
A Ford 283? Must have been a one off.
I was thinking my '68 Ford 1/2 T. was a 283????? Wrong???? )My 64 Ford Custom was 283.).... No doubt it had better gear and was a stick (usually better gear)...... I had an early 70's GMC 3/4 ton 4 speed 327, I am thinking, good gear. It was a trailer pulling sucker, Till I got a 76 chevy 3/4 T. 454, that was my brand and engine till the Ram Cummins came alone in late 80's. for me...
Unfair to belate Ford or any brand 1/2 T. trucks, gear makes all the difference and if engine is bout wore out or not!!! For any real towing, you need at least a 3/4 T. period...
Chevy made the 283. If it was a 68 Ford it was either a 289, or a 302. 68 was actually the first year for the 302. The 64 Ford Custom was probably a 260 if it was a small block. 221, 260, 289, 302, 351W, 351C, 351M, 400. That's the small block hierarchy. But of course beginning with the 351C those are the Cleveland based engines, but they are still small blocks. The 221-351W are all Windsor based.
I've never seen a factory 289 in a truck that late though, although I am certain they put them in.
Chevy had a 302 in a z28.
