Should I buy this 440?
It has a 933 oil pan with a baffle which is interesting. Here is some info from 440 Source.
Shown here is an original factory USED "933" oil pan. There were supplied by Chrysler as part number 3751934 in high performance applications which included the internal welded oil baffle, and as part number 3751932 in non high performance applications which did not have the oil baffle. See the table at the bottom of this page for exact applications, but in general, this pan was used from 1974 until the end of production on "C" body cars with high performance 400's and 440's. These are unique and easily identifiable because they are the only pan to have the drain plug on the side of the sump rather than the rear, where Chrysler usually put them on all other pans. If you are doing a swap, they will also fit 1966-72 B bodies and 1970-74 E bodies, although they never came from the factory in those cars. These are about 5" deep and hold 4 quarts of oil, plus one in the filter, for 5 quarts total.
