169dart4y
I'm trying to figure out why my 69 dart won't start after I did a slant six 318 swap? The ballast resistor gets hot when I turn the ignition to the on position like I'm going to start it.
There is nothing at the ignition when I try to start it, it will bump the starter if I cross the starter relay. Any suggestions
The only thought I have is one yellow wire that went to the starter relay and the electronic ignition were different on the harness when I converted the slant six harness to the 318 harness.I used the 69 slant six harness , the 318 was a 74 dart swinger harness. Everything works on the car except the ignition won't even bump the starter? All the lights work .
I tried to by pass the neutral safety switch and ran a wire from the middle post to the starter relay,nothing !
When you put the car in reverse the tail light come on .
Any thoughts I'm up for suggestions . Thanks
