side dipstick on 5.7
1967GTXhemi
Active Member
louisville ,ky
i am using a rear sump oil pan on my 5.7 but the dipstick on the side will not work because the plate between the pan and the block dosent have a hole for the side dipstick since i have already assembled the engine is there a way to cut that hole without removing the pan?
So all I can think of is the bottom of that hole doesn't need to be purdy. So what I imagine is drill to just a 32nd or so short of breaking through then cleaning the bottom with a flat nose drill or end mill, then punch out the bottom slug. You would still drop the slug waste in the pan but hopefully its not small enough to travel. You might retrieve most of that with a stick magnetic. Hope anything remaining collects on a magnetized drain plug. Ofcourse you would need to know the material thickness at that location. A whole lot of planning before careful work plus a bit of prayer versus pull the pan.
Remove pan
There is plug on the side of black. Tap out.
Buy new dipstick from a believe it's bullock . Did you change the pickup.
