Simple Suspension Bolt Question
rymanrph
North Carolina
I am installing a spring offset kit this weekend. I ordered the kit from US Car Tool that uses the factory spring hanger mounts to locate the brackets. Unfortunately, I don't have any of those bolts.
Can anyone tell me what size bolts (length and thread pitch) they are? I just need to pick up a couple from the hardware store, but I don't know what to get. Thanks.
I can get bolt sizes for the rear hangers. The front hangers have or had studs with nuts.
You need info for all ?
Both front and rear brackets use the existing mounting locations to position correctly, so yes if you can get both, I would appreciate it.
OK The stock hardware has kep washers and such so to do it with hardware store nuts and bolts 3/8-NC X 1.5 all around. The front hangers studs were 1.5 but showing only 1.25 ( after pressed in ). The stock rear bolt were only 1.25 But again if you're adding washers...
Hope this helps.
