[SOLD] slant 6 225 engines for sale
VDART
Shulte Ks
I have 2 225 slant's for sale in Wichita Ks 67209, i'm going to use the 1 bbl intake /exhaust for my 66 valiant -- to swap out the holley 4 bbl on it. Other wise both are long blocks-- 1 is a 5 freeze plug style & has a 68 & later crank in it -- the other came from a 75 duster -- but i do not recall the specifics on it.
he 75 duster car i drove briefly-- so it is a known running motor-- the other I do not know -- but it turns over smoothly & prior owner pulled for a v-8
i will sell most parts -- but preferably complete engines --$100 each
located in wichita ks, thanks Lawrence
Will you part out that A/C damper pulley (the rear one) I need one for a trigger wheel core. Thanks.
the engine from the duster-- i do not think it was original to it--- does that matter?
I do not have easy access to truck lines & this would not be a cheap proposal.
Lawrence
no-- but will have a 4 bbl & 390 cfm holley soon from a 1966 valiant 2 dr post slant car.
looking for 1 bbl to bolt on 65 dart, want a known runner to bolt on, second choice is known runner that would need cleaning and kit. prefer rod style. please let me know if you have anything. thanks.
SD- the slant in my 66 runs fine--
805 mopar kid -- read again-- pishta has already rec'd the pulley
Barbee-- I have a rod style carb but the accelerator pump arm is missing the correct screw
PM feature is the best way to contact. thanks
Does the A/C engine have Power Steering if so would you sell all the PS brackets including the one that mounts on the side of the engine.
I am interested in your engines if they are still available.
I live in Tulsa OK. so I could drive up and get them in my truck (Dodge of course).
First time at using this forum so if I am doing something wrong, just don"t kill me.
