SpriceyStuff
I’m trying to listen to everyone here. Not just to you. SorryYou're just not listening, so I wish you luck! My car runs great!
Have at it!I’m trying to listen to everyone here. Not just to you. Sorry![]()
check your PMHow much are you looking to get out of it?
It will never stop. Get used to it.Sigh.
When will the BS stop???????
[1] 750 Edel secs will never open. Yes they will, they are a mech sec carbs. The secs go to WOT when the primaries go to WOT. The sec vel valves may not move, but there is a lot of air leakage around them that could lean the mixture.
[2] Prim are no bigger than a 350 Holley. Yes they are: Edel Pri 1 11/16", Holley 1 1/2"
BWAHAHAHAHAHA! That was a goodun!Might need a more powerful toilet flush, to flush away the BS......
Running a 750 cfm carb of any brand on a slant 6 that will be street driven is a baaad idea. The large primary barrels will nit be conducive to good throttle response. There is a reason why manufacturers select carb size commensurate with the engine size [ & at greater cost ] , rather than a one size fits all.
Hey guys. I want to do a performance slant six build, and I originally wanted to do a triple Weber setup. Since I don’t have the cash and Redline hasn’t been able to resume manufacture of the manifold, I’ve decided to cut my losses and just go for the cheaper 4bbl route. I’ve found a manifold that’s in stock, but I want some recommendations for what carb to put on it. I’ve bought a bigger cam, and I’m
Hey guys. I want to do a performance slant six build, and I originally wanted to do a triple Weber setup. Since I don’t have the cash and Redline hasn’t been able to resume manufacture of the manifold, I’ve decided to cut my losses and just go for the cheaper 4bbl route. I’ve found a manifold that’s in stock, but I want some recommendations for what carb to put on it. I’ve bought a bigger cam, and I’m planning a set of 3-2-1 headers for the exhaust. How many cfm can I make use of? I don’t wanna blast all my cash away on a bigger carb than I can actually use, but I also don’t wanna miss out on any gains by going smaller than I can. What do you guys think?
If you use the AussieSpeed intake, it has no heat to aid atomization and vaporization of the fuel. A carburetor with annular boosters has better signal and they do a better job of atomizing the fuel than standard boosters. The Edelbrock AVS2 carbs have annular primary boosters. If your intended use is primarily a snappy street engine, I would go with a 500 CFM 1901 with electric choke.Hey guys. I want to do a performance slant six build, and I originally wanted to do a triple Weber setup. Since I don’t have the cash and Redline hasn’t been able to resume manufacture of the manifold, I’ve decided to cut my losses and just go for the cheaper 4bbl route. I’ve found a manifold that’s in stock, but I want some recommendations for what carb to put on it. I’ve bought a bigger cam, and I’m planning a set of 3-2-1 headers for the exhaust. How many cfm can I make use of? I don’t wanna blast all my cash away on a bigger carb than I can actually use, but I also don’t wanna miss out on any gains by going smaller than I can. What do you guys think?
This is kinda what I was getting from others too. Thanks for all the info! I’ll definitely look into the 1901 and the boosters.IMHO, unless racing only, the 1407 is too much for a street slant. Either keep it for a built a bit 360 ir sell it and use the money towards a 1901 Edelbrock.
If you purchase a 1901, it will come with the annular boosters.This is kinda what I was getting from others too. Thanks for all the info! I’ll definitely look into the 1901 and the boosters.
JEGS bought by a Chinese "firm".
That was my point in posting that link. However, just like everyone else, many if not most of the parts being sold by Jegs, are at least partially sourced from China. There is no way around that. The only thing we can hope for is just like in the late '70's and '80's stuff coming for Japan was garbage. The Japanese kept improving the quality of their product, until it was "world class".Where is the Chinese link? All the contact names for Greenbriar are Anglo-Saxon.
Follow up question: is there a baseline tune that I can start with? Something like “bottom out the screw then turn it back so many turns out” kind of thing that will get it running without having to fuss with it? I’m not planning on putting anything on the engine until I can take it all apart and rebuild it and put it all back together with hot rod stuff, including the cam. Since I’ll be breaking in my cam I don’t wanna have to sit there and turn it over again and again without it starting and building oil pressure.If you purchase a 1901, it will come with the annular boosters.
The boosters are to upgrade a performer carb.
I am confident that you will be happy with the 1901 should you go that way. I would get a calibration kit to tune it. One good thing about a carb is that it is not a maintainance part like brakes, tires and spark plugs.
This is what I originally wanted, but no one has the manifold in stock or will any time soon. I have been in contact with a guy in a warehouse in Australia and he was in contact with the manufacturer who said they broke their mold and have been since unable to resume production.I did the 4bbl thing on a hemi 6
wasn't as good as i'd hoped and ended up paying twice and now have webers
can't say any of these have stock other than they currently seem to have stock
MANIFOLD VALIANT SLANT 6 take 3 x DCOE WEBER - Redline
Chrysler 225 Slant 6 Triple 45 DCOE Weber Kit Weber Performance Carburettors
Redline Performance Intake Manifold - 12-52
Bro, as someone who spent multiple years in the motorcycle world, trust me when I say you do not want a multiple carburetor set up. You will need to buy tools(no big deal) and learn how to properly use them(big deal) to get the carbs synced. Once you have the knowledge and tools it can be fun, but until then it can be one big exercise in futility.This is what I originally wanted, but no one has the manifold in stock or will any time soon. I have been in contact with a guy in a warehouse in Australia and he was in contact with the manufacturer who said they broke their mold and have been since unable to resume production.
I tried. I gave up.SpriceyStuff is a nubie at this stuff. He doesn't need the complications, or expense, of multiuple carbs. Lets follow the "KISS" theory.
Keep
It
Simple
Stupid
Generally bottom the idle adjustment mixture screws lightly and then back each out 1 1/2 turns.Follow up question: is there a baseline tune that I can start with? Something like “bottom out the screw then turn it back so many turns out” kind of thing that will get it running without having to fuss with it? I’m not planning on putting anything on the engine until I can take it all apart and rebuild it and put it all back together with hot rod stuff, including the cam. Since I’ll be breaking in my cam I don’t wanna have to sit there and turn it over again and again without it starting and building oil pressure.
