cchrishefish
I was looking over my 64 Dart 225 slant 6 today, because I noticed a 190 degree reading on my gauge after installing the correct 180 degree thermostat. The radiator is clean as a whistle after flushing and topping it off with 50/50 mix. I noticed my radiator is 22 inches wide on the core, and the fan seems to not cover 1/3 of the radiator. The timing is set dead on. Should I consider finding a larger mechanical fan? If so, will a v-8 fan fit to give me the stock look, or should I go for an aftermarket flex fan? Part numbers and or sources would be helpful.
