[WANTED] Slant 6 Double Groove Water Pump Pulley
'64 Dart
NW Ohio
Good Day All
Adding A/C to the slant and need a pulley that is bargain priced.
Send a P.M. if you have one you want to go away.
Thanks to All
'64 Dart
For AC there is an add on pulley on the rear of the damper and a 2 groove pulley on the water pump. Don't confuse the crank AC pulley with the crank power steering pulley as they are different.
