[FOR SALE] Slant 6 HEI mounting plate
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
I have some slant six HEI mounting plates made by the Fabulous Ritchies Garage. Asking $40 each to offset Machining costs. I also have NOS HEI modules with a proper plug to attach to a gm 4 pin. Also have all the components needed to make this up
Mounting plate with screws, and heat transfer past just need a 10-32 tap for the distributor housing. $35
10/32 tap $12
HEI 4 pin Modules $25
Power wiring $20
Pick Up plates with the HEI plug $45 NOS
.03 ohm HEI cannister coils $125 Petronix III Fit in a standard coil mount
Complete Refurbished Distributor assembly ready to drop in with a mild street curve with my custom springs (will list separately). $325 without a core 300 with one Look way better in person Just need a .03 ohm coil
And the actual ride
Any Questions just ask.
Made a recommendation to this guy for your Slant 6 HEI conversion bracket and related parts as he wants to upgrade from the original points ignition, on his recently purchased '64 Dart Convertible.
