This is a nice set of pistons for the 198 long rod for the slant 6. They are new and never run. They were used for mock up only. They are standard bore for the 2.2 Chrysler 4 cylinder which is 3.445. They can get compression from a true 8.5 to about a true 9.5 depending on your build. Specifics about them are here:
www.summitracing.com
These pistons however, are press pins only. New pistons complete with new pins. Summit has them for 138 for a set of four. I will do 150 shipped to the lower 48 for these. I am selling these because I needed more compression for the large camshaft I plan to run. Located in middle Georgia. Thank you.
![www.summitracing.com](https://static.summitracing.com/global/images/prod/xlarge/uem-1291h-1-0mm_nk_xl.jpg)
CHRYSLER Silvolite 1291H.STD Silv-O-Lite Hypereutectic Pistons | Summit Racing
Free Shipping - Silv-O-Lite Hypereutectic Pistons with qualifying orders of $99. Shop Pistons at Summit Racing.
