slant 6 oil pan
6tshemi
Member
Gold Canyon,Az.
Let try this again.
I have a 66 valiant and I am putting a 69 225 in it but I don't have a 66 oil pan.
Found a pan but its not a early pan it has 265 stamped on it.
Will it fit?
I might be able to talk my brother into taking the Pan off our 61 Aluminum 225 if you wanna buy one. Its just lying on a crate right now in the back of the garage. (not gonna use the motor)
If you use the thick biscuit 65 mounts, your 67 pan may fit (can be hammered to clear, but do it bolted up so you dont spread the bolt pattern. ghetto) . It hits the straight crossmember so if you use a V8 dropped center, youll be ok. Best to get the correct one as they all have unique pickups IIRC. Heck, I may even have one if the AL motor falls through but mine is currently being sat on by a slant itself.
I have a V8 center link fer sale.
