gregpurcell
Greg Purcell
I recently bought a 72 Valiant with a 225 upgraded to the Super 6.
The guy said that the power steering pump leaked at the housing, so I decided to swap out an identical Federal pump I had in the shop. I started it up to work on another problem (Carb won't idle) and I set the idle high so it wouldn't stall (about 2500 RPM).
A few minutes later, the power steering started doing the "low on fluid" howl, and I returned to find my PS pump "boiling over" with fluid being violently forced out of the cap. When I shut down the engine, the pump was too hot to touch!
Did I just install a defective pump or should I replace the steering BOX? I have tons of parts, so price is not an issue..just the time and labor.
Any ideas or similiar problems?
Thansk!
Thansk!
