[WANTED] Slant 6 to 318 mounts needed!
Erick, I believe u can just use the thicker biscuit from a truck or van on the passenger side. As long as u have the factory K frame. Maybe someone else will correct me if I’m wrong. Drivers side uses the thin biscuit. Ofcourse u still need the brackets that mount to the block. Hope this helps. Kim
