1972gnswinger
Member
1972 dart swinger, we have the 360 in, everything is hooked up, all fluids in.
I checked the stance with the 6 from floor to fender at 26" and with the 360 at 26 1/4 to 1/2.
I weight the cast intake at 65#. So, with aluminum intake and headers instead of the cast manifolds, the 360 will be right at or slightly less in weight than the slant 6. Stock 360 only weighs 75# more than the 6. 475-550#
Will it still be nessesary to change torsion bars or anything else in the front end. This will be just a nice daily driver, not a racer. The only reason for the 360 was for sound and maybe a tire burn.
thanks for all the advise you guys give, made this conversion very easy.
thank you
thank you
