Spool mounts I believeWhat segment of the K member changed from 72 ~> 73? Trans Dapt/Hedman has the slant ~> BB adapters for the 67 ~> 72.
these guys bought schmacher out and will be selling the mounts.. may want to call them. MOTECH Performance
No 440 here, but all "normal" A-bodies have the engine off centered to the passenger side by nearly 2 inchesDoes anyone have a 440 in an A-body and if so, is the center of the engine slightly offset to the left?
I'm making my own mounts & my engine block is almost touching the steering gear box when I try to center the engine left to right. I've trimmed up the drivers side perch as per directions so everything else is clearing.
Thanks for info. I was wondering how I was going to get the engine closer to the driver's side with it was already almost touching the driver's side perch. I actually think I need to kick the engine a bit more to the passenger side so my motor mount doesn't touch the steering gear box. My mounts are out of 1/4" steel so a bit bulky and might need to be ground down or a notch cut out at the steering boxNo 440 here, but all "normal" A-bodies have the engine off centered to the passenger side by nearly 2 inches
The following is an email from the Schumacher with the owners last name removed, not sure he wants everyone knowing his full name.
My name is Chris ____, new owner of Schumacher Creative Services. That kit, A73B6, is slated for production around the first of the year. I can put you on the list and let you know when they’re ready.
Thank you
-Chris
Schumacher Creative Services Inc.
[email protected]what is chris's email?
