[SOLD] Slant 6 Triple 40DCOE set-up
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
Looking for that out of the ordinary engine compartment bling for your slant? How about a triple Weber set-up? Here's the particulars on the set-up: The manifold is a Clifford, which I think has long been out of production for the slant. This one has had a power brake vacuum port added on runner #4. The carbs are genuine Italian Webers - not the Spanish variety - all matching numbers: TIPO 40DCOE 149, No 5/0 or maybe 50. As I understand it, this is important when running multiple carbs as all internal components - jets, emulsion tubes etc. should be all the same. Included is the linkage, 6 Ram tubes, braided fuel line with AN fittings and a new set of 33mm chokes. The carbs currently have 30mm chokes now. This set-up has not been used for at least 6-7 years prior to my acquisition in 2010 so I would say at the least each carb should be disassembled, cleaned, all jets, emulsion tubes, etc be verified they are the same and re-gasketed. I am asking $1000 well packed and shipped to anywhere in the US. Message me if you need more information or additional pictures.
