Cudafishboi
For sale is my good ole 225 slant 6 was freshly rebuilt about 92 miles ago.
The cam was ground professionally by oregon cams. (Mild grind)
This was a complete rebuild from top to bottom new pistons new rings, the head was cleaned up by a local shop, new valves and pushrods. Aside from the cams mild grind everything else was pretty straightforward stock.
Upgraded to a clifford 6=8 intake, with headers and a weber 2bbl carb.
Runs fine just bought a 318 that I need to build up for it.
Comes as you see it with all the accessories if you want em. Will even let you take the custom exhaust I made for it. As well as the 904 transmission.
Currently still in the car but can pull it anytime.
Only difference is the valve cover isnt chrome anymore.
Its a solid good little engine. Only reason im getting rid of it is to put the 318 in.
1500 and its yours. Located in va, 23518
