Rengo
What would be the best 2bbl carb. on a 225 @ .30 over with a 904 trans. and a stock rear end.
Should I run 350 cfm or is that to much?
If I recall the Holley 2280 flows at 350 cfm. The carter bbd is pretty much the same thing. I was also looking into a 2300 but idk how efficient that would be.
you are right the roomates dd has one on it,made it run much better esp on the highway....I think a 318 carburetor would be perfect.
