[Found!] Slant six electronic distributor cores needed.
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
I need some slant distributor cores electronic. What you have? $15 a core and the ride? I will be at Chrysler Carlisle in O-190 also.
I have some. points, electronic with advance, electronic fixed single pickup, electronc dual pick up
Let me check in a day or so. I need to keep some for myself.
Sure the single pick up is what I need. The dual are lean burn. If it is single and locked out that is ok can use the parts for custom. Thanks.
