[Found!] Slant Six Engine Bolts
halfafish
Damn those rabbits, and their holes!
SW Washington
I bought a nice slant from a local guy that needed a go-through, and I am well on the way to assembling it. The bottom end and cam are all in and ready for the next step. However, when I bought the engine, it came disassembled in boxes. No problem for the most part, but.....................either I did not get all the bolts that go with the engine, or I lost the bag of bolts. So, I need a LOT of bolts. If someone had a destroyed slant they didn't mind stripping these off of, I would be a happy camper. Especially if they were bagged and tagged so I don't have to figure out where they all go the hard way.
The bottom end is good. I have the oil pan bolts and dampener bolt. But I need the following, with all their washers if they have them.
Head bolts
Intake/exhaust - bolts/studs/washers
Oil pump bolts
Water pump bolts
Timing cover bolts
Distributor bolts
Valve cover bolts
Fuel pump bolts
Cam bolt (for the timing gear) and washer
Thermostat housing bolts
Intake to Exhaust manifold, heat stove bolts
I did find a bolt kit that was fairly reasonably priced, that covers the above but it DOES NOT include head bolts. So at the very least, I'm looking for a set of head bolts.
Thanks FABO for the help!
I would have most of those , I will have to dig for them. I do have head bolts
Ray - I think I have an extra set of head bolts, possibly some of the other sets. Will check.
