[FOR SALE] Slant Six Parts from '69 in CT
neophile_17
Southington CT
Hey guys,
I posted this add before but since then my shed was damaged and I need to clear things out before repairs can begin. No parts were damaged. Parts are located in Southington CT. Prices do not include shipping.
Engine & Head:
116k on odometer. FREE! Will come with new head gasket and valve cover gasket or two. Local pickup only. Minimal ring ridge on the block, will measure if interested. Timing chain was stretched so that will need to be replaced. Ran well at RPM but struggled at idle due to valve lash and timing chain.
120Amp Alternator:
Bought new a couple years ago and has less than 2,000 miles. Pure Energy 15686N new was $85- yours with a new belt for $55. Works with the /6 but also many others.
Fuel Pump:
Delphi AMF0018 never installed. New in box $10.
Thermostatic Choke:
Carter 170-687 never installed. New in box $25.
Original Starter:
$15
Holley 1920 Carb:
Free with other purchase. Rebuilt but bowl doesn't seal without the help seen in the pic despite MANY attempts to do it the correct way.
Original points distributor with new Vac advance:
No signs of wear on shaft which can be a problem. $10
Electronic distributor:
Originally from 1985 D150 but we retrofitted it to the '69 with the HEI setup. Comes with cap and 8mm wires -$25 ~Shown above with alternator
HEI retrofit:
Coil, Module, and Relay to add HEI to a Mopar electronic distributor. $55 or combine with electronic distributor for $75.
I'm trying to be reasonable/cheap with these prices but I've only been on the Mopar scene a little while. If you see something you want but it seems overpriced PM me an offer.
Thanks for looking!
Sam
Hello,
I am interested in the Electronic Distributor if it is 3874714, and maybe the HEI conversion too.
I live in Orange County CA.
Ken
Your post below:
HEI retrofit:
Hello Ken,
Thanks for the interest. Work has been a little crazy for me and the weather hasn't been great for making a trip to the shed in the dark but I will get out there on Saturday. I'll send you a picture when I do.
Sam
Distributor Pics as requested. I couldn't quite make out the part number. Is there something in particular that I can look for to identify the model you're interested in?
Conversations aren't allowed on sale threads. Thanks.
