Slant six question
76ranger
Member
Garfield hts ohio
Im in the process of reinstalling a slant six into a 76 plymouth duster. My question is there suppose to be a plant between the trans and motor? Thanks David
"Im in the process of reinstalling a slant six into a 76 plymouth duster. My question is there suppose to be a plant between the trans and motor? Thanks David "
Uh...yea dude,....maybe a pot plant.....uuuh....what was the question???? :tongue10:
Google says: "Did you mean"
Were you asking about a plate? If so, then your answer is no, there is no plate between the engine and the transmission.
I meant plate. And yes between the trans and motor. This is my first mopar experience , I've always messed with fords and chevys and there has always been a spacer plate between motor and trans David
Engine bolts to transmission bell housing. Inside bell housing is flex plate and converter (if auto) or flywheel, pressure plate/clutch assy. (manual).
Hope this helps,
Frank
Maybe you're thinking about the inspections plate or cover on the bottom or forward end of the auto transmission.
The only difference between Chovy and Mopar is that Chivy uses a flex plate that has the starter gear on it, so it's round
Mopar uses a flex plate that is "4 pronged" and the starter gear is on the converter
But the factory Mopar plates suck and are weak with any applied torque worth a snot. even with a hot slant, you are likely to break one. I would look at the offerings from B&M. If you get one from them, you will bolt it on and NOT have to worry about again.
