robertob
Freshly reground crank, 10/10, by a local crank shop. Never run, only test installed.
$75.00 plus actual UPS ground shipping, or pick up in Long Beach, CA.
This is from a 1968 up motor, you can use in earlier blocks with the right flexplate/spacer ring to match the transmission.
Generic timing set, also never run with no box. $20.
