Slap Shift in a 72 A Body??
applescj
Meridian, ID
I would like to install a Slap Shift mechanism in my 72 Demon, what is involved???
Ant help would be appreciated.
My Dads Dart Is a Stock shifter Console car. In order to use a Slap Stick all you half to do is use This linkage (Red Arrow Pointing at it) and attach it to the Slap stick and then you are done. The linkage should be on your Stock shifter.
Love those Slap Sticks. I would have to have one too if I had buckets. I had 2 73 Challengers. They are great!
I'm assuming possibly your car may not have a floor shifter?
If not, frankly you need a donor car, and just take the whole shootin' match.You'll need
the spot welded mountings,and you should make a cardboard template of their relative
positions before knocking the welds apart. If you already have a floor shifter/console,see
the above post and slapstik away!!
I'm sure the ants around here will do all they can, and I have
way more than i can handle,just tell me where to ship them and i'll box up as many as
poss. immediately!!
