Slow, Driving Rustoration 1972 Dart
Hate to say it, but the rubber "core plugs" have been known to pop out under hard acceleration/ high rpm over time. BTW, we refer to them around here as "soft plugs", no matter the material they are made of. Like the car, we just did a driver '72 Scamp for my son.
Nice ride!!! We had a 318 3 speed 71 Scamp in the mid 80s.
An engine and transmission rebuild are in the Dart's future. I'll whack some brass ones in when they are accessible.
So for the past 8 weeks or so my partner and I have been taking short trips out of town every Sunday to get breakfast in a small town cafe. The longest trip so far was about 140 miles round trip. The Dart is getting about 16 mpg on these county roads and has been almost flawless. The only things that have been broken are the climate controls and the driver's vent window. The vent window almost fell out when I was opening it on a dirt road and the climate control only works on the AC setting. So I took the heater/AC control switch out and just jumper wire the fan on and off and adjust the blend doors manually.
As it has started warming up lately I decided to finally get the AC working too. I ordered a new heater/AC control switch online (won't be here til Tuesday) and got a new drier and expansion valve. I got them installed today, rented the vacuum and gauges from O'reilly and got everything working tonight. I'm still working out of my driveway and it got dark as I ran out of freon. It was about 80 degrees F at the time and it was blowing out really cold air. It was starting to freeze up on the low pressure side of the evaporator and the sight glass was still partly cloudy.
I need to crawl around and make sure the evaporator drain hole is clear before taking it out for a test ride.
Oh and on the last breakfast trip it hit 12345.6 on the odometer
Facebook link to our breakfast adventures.
So I got the heater control switch and changed it out only to find that the problem was with the blower resistor and not the switch.
To make matters worse I installed an uninstalled the heater control assy at least 10 times. It would work great at switching between AC/Heater/Def when it was hanging loose. But as soon as I tucked it up under the dash and bolted it in, it wouldn't switch between Def/Heater. I finally realized that it was leaking vacuum once installed. I found that I had to adjust the vacuum plug once it was installed.
By the time I got it figured out it was dark so I guess I'll finish it tonight. Maybe the radio will help support the vacuum lines, if not, I guess I'll install the old switch and see if it has a better seal.
Got everything buttoned back up today with a "repaired" loop on the blower resistor. Did a road test and with temps around 83 it was cool enough in the car. I still am about 12oz low so I expect this will be pretty good this summer, at least on the highway. I somehow lost the little chrome button for the temp slider. I'm sure it was one of those "I'll put it here so it will be safe" things. :rolleyes:
I also installed the windshield washer tank and replaced all of the hoses. I've had the new tank since 2018 so it was past time to install it.
WOW! So much empty.
I've had a rough 3+ years. My partner was diagnosed with aggressive breast cancer in early 2022 and passed away right before thanksgiving 2024.
In 2023 we took the Dart on many road trips for breakfast with friends. These pictures are from a trip with 6 people in the Dart.
In 2025 the Dart was my daily driver. I've known since I started driving it back in 2019, that #7 cylinder was low compression.
#1 - 120
#3 - 135
#5 - 135
#7 - 85
#2 - 140
#4 - 140
#6 - 130
#8 - 130
It has actually been running and idling well for the last 3 years. I haven't had to touch the idle mixtures screws or anything. But toward the end of this summer of daily driving highway and in-town. I noticed a loss of power increasing steadily. I haven't redone the compression test yet, but I am planning on doing a re-ring, stone hone, and valve/head cleanup this winter. Going to try and keep the downtime to a minimum as usual. I might also start doing actual metal work to bring the rust under control. You may remember my bondo rust "repair" from nearly 6 years ago. It finally gave up the ghost last winter and is bubbling fairly badly.
Wish me luck! I haven't been this deep in a car engine since vo-tech almost 40 years ago. Watching a lot of Dead Dodge Garage lately has somehow given me something resembling confidence.
... and remember sometimes you can't Dodge a Dart.
Maybr ook for another 318 you can rebuild while driving this one?
So very sorry for your loss. I wish I could have the ability to say something better. Life is all about friends, family and memories.
There you go,, spare engine! But really, you can pick up a good teener for pennies. They are great engines that seem to rarely get their credit they deserve!
WOW! So much empty.
View attachment 1716487897View attachment 1716487898
#1 - 120
#3 - 135
#5 - 135
#7 - 85
#2 - 140
#4 - 140
#6 - 130
#8 - 130
Sorry for your life tribulations.
you can do it!
