rick1062
Active Member
Hi folks,
I am working on a 1965 Barracuda with a 273 engine and a 904 trans, all basically stock.
I have posted other questions about this car and received great help from this forum. One thing is the car was missing some of the throttle pressure linkage. I was able to find some linkage, installed and adjusted it as the manual says. So, I think that problem is put to bed.
Now that we have it running pretty well, we find when accelerating, the car shudders some and feels to me like the trans is slipping. If I ease off on the throttle, the shuddering stops or at least lessens by a lot. A second problem with the trans is that from park, the trans won't always engage in reverse, or sometimes forward. When it won't engage in reverse, and I move the shifter back into drive, then into reverse, it will usually engage. When it won't engage in forward and I move the shifter up to reverse then back to drive, it usually engage. This doesn't happen every time, but often.
I don't know if the shuddering and the non engagement into gear are related, or not. But if any of you have ideas, I would greatly appreciate any advice on these issues.
Thanks as always,
Rick
Thanks as always,
Rick
