Small Block 360 Parts
68kingcuda
Active Member
NC
Rating - 0%
0   0   0
Small block mopar edelbrock valve covers new $100
Billet roller timing set &100
two set of 1.5 iron roller rockers and 1 set of rocker arm shafts $300
Race W2 68cc with valves $1200
Indy intake new $400
mopar high volume oil pump new $50
3/8" pick up tube $50
2 moroso oil pan new & used 8 qt $200
4" crankshaft 4340 steel(360) ohio crankshaft $605
ohio crankshaft rod H beam 6.123 new $390
main girdle kit $280
360 block stock $100
Engine plate A body small block $75
comp cam roller cam with cam card new 660 @.50 288/296 CL 109 $200
roller lifter new $280
distributor Bronze Gear for roller
will sell everything for $3800
Will neg on the parts just hit me up
Has anyone spoken for the roller lifters? Can you tell me the make and model please?
parts pic
heads w2 race not econo
