[SOLD] Small block/360 rings, bearings & spark plugs
Locomotion
Florida
Piston Rings -
* Total Seal CRG 3690-45, 4.040" bore file fit, 1/16"-1/16"-3/16", low tension - $90.00
* Childs & Albert RS 10477-25, 4.020" bore file fit, 5/64"-5/64"-3/16", low tension - $90.00
* Childs & Albert RS 10477-45, 4.040" bore file fit, 5/64"-5/64"-3/16", low tension - $90.00
* Mahle/Perfect Circle 315-0034.035 , 4.030" bore file fit, 5/64"-5/64"-3/16", std. tension - $90.00
* Mahle/Perfect Circle 315-0036.065 , 4.060" bore file fit, 1/16"-1/16"-3/16", std. tension - $90.00
* Hastings 2M 5505 035, 4.030" bore file fit, 1/16"-1/16"-3/16", low tension - $85.00
(I believe these are low tension oil rings. Hastings website & Summit doesn't say, but Ebay ads say "low".)
Main Bearings-
* Clevite MS-1051P-10 - $75.00
* Speed Pro 120 M -Std. - $60.00
* Speed Pro 120 M -10 - $60.00
Rod Bearings -
* Sealed Power 8-2130CP-20 - $25.00
* Sealed Power 8-2130CP-30 - $25.00
* Sealed Power 8-2130CP-30 - Not in original box. Mocked up in rods but never assembled - $20.00
Cam Bearings -
* Mopar Performance P5249710 - (2 sets available) - $20.00 ea.
Spark Plgs -
* NGK GR4 (12 plugs total) - $30.00 for 12 spark plugs
All prices + shipping.
I'll find the cheapest rate, usually Regional Rate Priority Boxes.
Shipped from Florida 32117
Sorry, no PayPal.
Top ring set is for std bore 340 correct ??
will those fit those [Lite weight ] old school TRW Dome 340 pistons ???
If so put um on my tab
