1973dusterkid
Watch This
What will it take to mount my small block 833 to a 400 block I know bell housing need swapped but what as far as clutch/flywheel and z bar setup.
same flywheel fit but its only a 10 '' disc need more like 10 1/2'' or 11''(143t flywhl requires 143 t belhsng ) or twin disc can be smaller , z bar is to lite and wrong length , mopar performance sells a z bar kit for big blocks , the clutch release arm can be a hard one for an a body , but there is complete juice set ups out there to handle that . on the trans , does it use the 727 slip yoke or the flange type ( can be converted to a yoke for a u joint , there both okay . but there is one that uses the 904 slip yoke . its a lighter load trans .
Good to see you interested,again...What will it take to mount my small block 833 to a 400 block I know bell housing need swapped but what as far as clutch/flywheel and z bar setup.
