Chris Henry
Member
Hi all,
I have a 72 Duster. No frills 273, aluminum water pump.
I am looking for an alternator bracket (triangle) that is mounted to the water pump. Also looking for the water pump pulley to go with it. Single groove as I have no A/C.
Trying to work through all the garbage the previous owner cobbled together.
please let me know.
Thanks,
Chris.
update:
The pulley I need will have a depth of 3-3/8” and an OD of 5-7/8. Double groove is fine if I need to make adjustments.
See picture for the bracket. Run-of-the-mill three hole bracket (water pump to alt top)
I’m really not sure if any of any of this stuff I have belong (doubt it). Just trying to get what I have to charge and not flop around.
I am going to the salvage yard today. I’ll update if I find something there
thanks
Chris
Update:
I found the parts I needed at the local salvage yard.
Thank you to all that replied. I appreciate it very much.
Best regards,
Chris
please let me know.
Thanks,
Chris.
update:
thanks
Chris
Update:
Best regards,
Chris
