Hi I've removed the complete drivetrain from my 73 dart. Rear end rebuilt and installed. 727 trans rebuilt, k frame out and all new suspension parts are all installed except for the linkage and brakes. Everythings painted and ready to go. The engine bay has been repainted. The engine is at the machine shop. I should have it back shortly to finish.
I removed the transmission first. Then the engine out the top. I wasn't planning on pulling the k frame and the doing the front suspension rebuild but it needed it. When I removed the engine the headers were shot so I cut them out making removal easier. I was just going reinstall in reverse.
So with everything out I am considering installing the engine, transmission with all the components on the k frame. I'm installing a new manual steering box, Doug's headers and mini starter. Everything on the k frame - Lift the body - slide in the engine / trans and drop the body back on the k frame. I've done it before on a LS1 trans am without issue. Looks to me like the way to go on the Dart too.
Has anyone installed one this way? Anything I should be aware of ahead of time? The steering column is still in. The headers on the driver's side seem like they may be iffy. I'm not sure due to different style header and cutting the old ones out when I removed the engine.
Any suggestions will be appreciated. Thanks
